1 - 8 of 8 Posts
I have 2016 Cruze limited and the cooling fan goes into turbo mode for 5 seconds and then off for 30 seconds and repeats. It really only happens when the AC is on. Anyone have any idea how to fix this? Thanks in advance.
I tried unhooking the battery
Have you checked your coolant level?
Does it when I’m driving also even at high speeds.
I think you need to take the car to a A/C shop. Something's wrong and it's causing high pressure - which triggers the fan.
Fans are not normally needed "at high speeds". So, that's the giveaway to me.
If the car's still in B2B warranty, (3 years/36,000 miles), then take it to the dealer.
This has been happening to my car as well over the last few months. I have taken it to a NAPA service shop and the low and medium resistors have gone on every single replacement fan, for a total of THREE fans. I'm going to have the dealer swap it with an OEM part on Thursday. This all started when my A/C went out. I have posted most of my experience on here for more inputs.
Following up on this in case you still are having issues. After having the dealer put in a new fan (plus fan shroud since the place I had it before replaced both) so far it's running fine. The OEM fan has lasted only a few days so far but that's days longer than the other ones did.
1 - 8 of 8 Posts
