Hi Good Day, today in the the morning i open the bleeder which is located on the back side of the left corner, when i opened coolant came with little pressure, then I opened the cap of surge tank to remove the whole air when coolant was coming continuously then i put back the bleeder valve cap and fill the surge tank. After that i drive the car approximately 30 km. But I didn’t feel like fan is on . On the other side when I parked the car after driving I didn’t feel like water is boiling inside the engine outlet pipe as well as radiator outlet was not that much hot.Boiling might be an overheat, but it might also be a leak that's not allowing pressure to build. Without a temperature measurement, you can't tell if the engine is overheating.
The fact the fan runs with the A/C proves the fan itself is OK. That's the usual failure point in these cars.
You also might make sure all the air has been purged. That's another common issue.
No i didn’t feel like coolant is leaking because i loke to check every time when i am going to check.Fwiw, if the cooling system has a leak and the pressure can't build, the coolant temperature can't get above 100 C. And the fan is probably set to come on at about 110 C.
If you fix the leak, I'm thinking the fan will start working.
