Man, what a trip. Summary:
- The weight of the car is pretty brutal. No shocker there.
- The tires have no traction. No shocker there.
- Combination of the two above = no bueno. No shocker there.
It was actually pretty interesting. Our courses are not like some of the courses I've seen out on the East Coast that are shoved into a 600 sq ft pad. We have some decent stretches to get the engine up a bit and usually throw in some tighter sections on either end, so it turns out to throw the most at the car you could get. Of course every different club designs the course for their specific vehicles, so that goes any which way.
Notes:
- Under hard acceleration heading into a transition, the back end seems to float around. It doesn't feel very planted. Not sure of the cause of that right now.
- The car plows HARD with the combo of weight and tires stated above. But knowing that allows proper planning of the upcoming corners and allowing the car to float over the course and not trying to make it stick to a line actually works a little for maintaining speed.
- Someone mentioned prior that they felt that traction control ON helped the car feel more consistent. I'll agree. However, I was about 1 second faster on a 75-ish second course with the traction control OFF. Could have been psychological.
- I had the tires at 40 up front, and 36 in the back. I rolled over on the front just the right and expected amount. The rear tires however, barely looked like they had been scuffed beyond my daily driving marks. Very interesting. I'm still not sure after one event if the higher pressure in the front is more beneficial or not. Hard to guess on such a hard compound tire. It almost feels in the gut as if a lower pressure would be better to help the tire move around and not push as badly. But I'm pretty leery of trying that. Rear pressure will decrease in the next event.
- Power band is just not right where I want it. I'm considering going to the Dunlop street tires on an alternate rim in a smaller diameter to get the gearing a little better. The car never got into a wound up feel, so it still has a lot of room. Tire induced gearing will more than likely help.
- Nothing to be done about the weight. Deal with it. Try to get better traction and gearing to offset.
- Suspension in the slaloms was actually very nice. I was able to keep my foot in it longer than I was with the Focus or the xB. Both of those cars exhibited more torque, higher power, and lighter weight than the Cruze, but the Cruze felt really nice as long as it wasn't a prolonged throttle where the reference to the lightening up in the rear was felt. Even after the lightening in the rear happened, a hard turn in didn't really upset the back of the car. Again, there wasn't much unwanted movement from the back tires. Just that strange float from the chassis.
Had a pretty good time. Always nice to get into a new car and get beyond the "But I don't want to break it" stage. This is far, far, far from a class winning car. The Mini will still crush us. I was about 0.6 behind a Mazda 3 after the 3rd lap with the Mini about 5 seconds in front. I was about 5 seconds faster than a Prius on average, and about even with an 05 Focus with better tires. So I believe a better tire on the Cruze would help secure 3rd with the group we had today, but still be a 4th or 5th place on what we normally have out there. No way to catch a Mazda 3 and especially a Mini.
I lost my home made camera mount, but I did take some video to capture the sound of "low rolling resistance death." Didn't turn out as well as I had hoped, so I may or may not get around to posting it.
This is not going to help my Fuelly numbers, that's for sure. After 4 75 second runs and some idling, I was at 7mpg average. :tank:
