Yep, but I bet it does 0-40 pretty quickly. Diesels are usually good at the low end. Also, they do measure 0-62 (aka 100 km/hr) in the UK. Also keep in mind that they tested the hatchback version, which is heavier.**** 0-60 in 9.4 seconds.. (sigh)
Well that's Imperial gallons based on the UK test cycle which is like 50 mph, IIRC. They say it translates to the 50s in American mpgyeah but Fuel economy: 72.4mpg
I would trade in my gaser for that.
That's about what many journalists reviewed the current Cruzes for. Even the heavily modded Cruzes have a very hard time breaking into the 14s in the 1/4 mile, but they will walk most cars that are technically faster than them.**** 0-60 in 9.4 seconds.. (sigh)
We haven't had anyone break into the 14s yet.... I don't really see it happening but I'm a skeptic. Cruze does pretty well in the 1/8th tho.. It can run ~10 flat even a tad quicker.That's about what many journalists reviewed the current Cruzes for. Even the heavily modded Cruzes have a very hard time breaking into the 14s in the 1/4 mile, but they will walk most cars that are technically faster than them.
Well it does have 221 lbs of Torque, compared to 148. That will make it better on hills and quicker from a stop. You could even tow a small camper with it.Great... wanted the 2.0TDI to come not the 1.7TDI!! GM will probably go with this for the states and its even slower than our 1.4T![]()
Torque has nothing to do with speed. It will make it better on hills your right, because torque is the load the engine does. Horsepower is how fast it does it. Hence, why on sports cars they advertise horsepower instead of torque. Work = Force * distance (aka, torque lb-ft!). Horsepower is a unit of power, which is rate of work. The diesel could have 500 lb-feet of torque, but as long as that little engine still says 130 horsepower, you aren't going anywhere fasterWell it does have 221 lbs of Torque, compared to 148. That will make it better on hills and quicker from a stop. You could even tow a small camper with it.
:th_coolio: Wise words, Grasshopper.№1: Hp is how fast you hit the wall.
№2: Torque is how far you push it.
Hp and torque was once explained to me when i was a young pup this way.
I think that's backwards. Torque in units is lb-feet aka work. Horsepower is the rate you do work. He said it perfectly.. how far you push the wall (TQ) vs. how fast you hit the wall (HP).Another way to explain it is that HP tells you how fast you will go (maximum speed), while Torque tells you how fast you'll get to that maximum speed.
So, if you could theoretically build a vehicle with 1000 HP and 50 lbs of torque then the car will eventually go 200 mph, but it will take you all day to get there.
Indeed. Think back to semi trucks. Gobs of torque and little (comparative) horsepower.I think that's backwards. Torque in units is lb-feet aka work. Horsepower is the rate you do work. He said it perfectly.. how far you push the wall (TQ) vs. how fast you hit the wall (HP).
That is because torque is the work being done. Peak torque just means the powerband where the engine is doing the most work. Horsepower is how fast the work is being done. Hence, you never hear sports cars touting their torque ratings - no one cares. 600 Horses = faster than 550 horses.I disagree. The rate of acceleration is directly dependent on torque, which is why you shift near the peak of the torque curve for maximum acceleration.
You can have all the HP in the world, but if you gear it for low torque, then you're not going to accelerate very fast.
So explain the Honda S2000. 240hp and 153lb-ft of torque. 0-60 in 5.3 seconds and 1/4 mile in high 13s.I disagree. The rate of acceleration is directly dependent on torque, which is why you shift near the peak of the torque curve for maximum acceleration.
High power to weight ratio. Also, it doesn't mean that an increase in torque wouldn't get the car off the line quicker.So explain the Honda S2000. 240hp and 153lb-ft of torque. 0-60 in 5.3 seconds and 1/4 mile in high 13s.
