It's not my intent to start a thread for or against ethanol fuels. I don't want to debate what you may have read, or the food supply, or other stories of ethanol. I want to discuss ethanol E10 and E15 in a 1.4L turbo without increased injectors and with a stock tune. Is it equal to mid grade, and how is knocking effected?
I just filled with my first tank of E15, and I normally run 89 Octane E10.
Has anyone noticed the coolant temperatures actually running slightly lower with the E15? I know the car drops coolant temperature when coasting under Fuel Cut off conditions, so maybe that's a combination of what I'm seeing.
We're also probably off winter gas where I live onto the summer blend, which should help fuel economy. I need a few hundred more miles to do some hand calculations on mileage, but based on the over optimistic DIC cluster, this appears to be one of my better tanks in the vehicles life.. 150 miles in with a DIC display of 43 mpg.
I've done two data logs using the Torque app, and it doesn't seem to be knocking that much. There's an area on my drive home from work that records knocking even with 91 octane, and I'll have to run a few more tanks of E15 and then go back to the 89 E10 to compare.
This fuel is from a local independent station, who sells E85, E30, E15, E10 and E0, diesel, and propane. I don't know if the E15 product comes in blended to the station, or if it's blended at the pump. There's a lot of fuels at this little station to have separate tanks for each, so I suspect there might be some blending. In this case it could be possible that if the blending is off using a higher quality of gas as the blend base stock this maybe showing a difference.
Fuel trims on Torque remain 0-4% for short term and long term fuel trims, so it doesn't appear that this fuel is significantly leaning out my engine.
So far I'm impressed, anyone else do some data monitoring with E15?
