Fluid Capacity Spec List
39542 Views 1 Reply 2 Participants Last post by  EricSmit
Fuel Tank Capacity:
Application
Specification
Metric
English
Fuel Tank Capacity
48 liters
50.72 quarts
Approximate Fluid Capacities
Transmission Capacity
Application
Specification
Metric
English
6T40/6T45/6T50
  • Valve Body Cover Removal – Approximate Capacity
5.0–7.0 liters
5.3–7.4 quarts
  • Fluid Change – Drain Plug – Approximate Capacity
4.0–6.0 liters
4.2– 6.3 quarts
  • Overhaul – Approximate Capacity
8.0–8.5 liters
8.5–9.0 quarts
Application
Specification
Metric
English
Transmission M32
  • Transmission Fluid Capacity Dry Transmission
1.9 liters
2 quarts
  • Transmission Fluid Capacity Refill
1.8 liters
1.9 quarts
  • Transmission Fluid Capacity Re-Manufactured Transmission
1.5 liters
1.59 quarts
Coolant Capacity:
Application
Specification
Metric
English
Cooling Filling Quantity
  • 1.4L (LE2)
5.2 liters
5.49 quarts
Engine Oil Capacity:
Application
Specification
Metric
English
L3A, L3G, L5Q, LE1, LE2, LFV, LVG, LV7, LWT
Oil Capacity
4.0L
4.2 quarts
1 - 2 of 2 Posts
For the 1.4T:
Cooling system 6.2 qts
Engine oil with filter 4.2 qts
Fuel tank 13.7 gallons (except for LS auto, 12.0 gallons)
Spark plugs between .024-.028 in
For the 1.6T diesel:
Cooling system 4.8 qts
Engine oil with filter 5.3 qts
Fuel tank 13.5 gallons
100 lb ft of torque for all model lug nuts.
Text Font Line Number Parallel
1 - 2 of 2 Posts
