Flushing of brakes
984 Views 3 Replies 2 Participants Last post by  aaron.terveen
I went to flush my brakes, but I was unable to remove a piece of plastic in there. Any ideas, or is that impossible to remove so I can take most of the fluid out?
1 - 4 of 4 Posts
The hard work is done!
Flushing the brakes requires the complete system. Not just the reservoir. You'll be sucking in the old stuff with the new stuff every time you use the brake pedal.
Best thing to do is have a shop that has a machine to flush the system. They can force fresh fluid through the system with all 4 valves open.
However, You can use a vacuum pump and suck the fluid at the valves. Just make sure the reservoir stays full. Don't let it dry out.
Bummer!
1 - 4 of 4 Posts
