This. Only other way would be rewiring them but you may need to have a different switch to have them turn on.If you have the fog lights on & make a quick stop(under 10 minutes), they will be on the next time you start it.
That's interesting, could be since I use the intermittent wipers 95% of the time I never noticed this, will have to test this out tomorrow. I wonder though if it was just one of those days where it got dark enough to trigger the automatic headlights to engage.My headlights turn on when my wipers are on atleast med speed for about 3 min. Noticed on a long highway drive with periods of rain. After a few min with wipers on the headlights and park lights turned on. After turning the wipers off for a few min it goes back to Drl's.
I notice with my cruze the DRL being the dimmed headlight bulb people can't see my turn signal blinking from the front when turning during the day. I wonder if this is why GM made the 2015 cruze have the separate DRL LED strip?The problem with DRLs is drivers often forget to turn on the regular headlights when dark as they already have headlights "on", but no tail lights. I have never been able to understand why tail lights do not get turned on with DRLs? It seems like a simple thing to do and a major improvement in safety. Also DRLs should be at the very least a dimmer headlamp not the little yellow corner markers. So many drive around in poor visibility with DRLs only (or nothing) and you can't see them, they don't have the sense to switch on their regular headlamps. That is why all these "features" are law now.
As long as your lights are on auto, the exterior lights will come on after (i believe) 7 swipes of the windshield wipers. So if you're on the lowest intermittent setting this could take a while. This is also why I try not to turn my wipers off when it's barely misting - I just use the slowest int. setting. Test it next time, leave your lights on auto and turn the wipers on and let them pass 7 times and see if they come on. They should.That's interesting, could be since I use the intermittent wipers 95% of the time I never noticed this, will have to test this out tomorrow. I wonder though if it was just one of those days where it got dark enough to trigger the automatic headlights to engage.
My real issue is with the automatic headlight system on most cars, people don't realize they are driving around with no tail lights in the rain/fog. That's why I love my fog lights, the parking/tail lights remain lit no matter how much light the automatic headlight system sees that minute. Hate that time of day the auto lighting keeps switching on and off as I drive through a dark valley or up on a well lit ridge.
I'll have to try it 7 times, I tested it this morning and it did not come on though I probably didn't do it that many times.As long as your lights are on auto, the exterior lights will come on after (i believe) 7 swipes of the windshield wipers. So if you're on the lowest intermittent setting this could take a while. This is also why I try not to turn my wipers off when it's barely misting - I just use the slowest int. setting. Test it next time, leave your lights on auto and turn the wipers on and let them pass 7 times and see if they come on. They should.
I'll check mine later today - I think it's seven. Make sure you have the wipers on and leave them on, because this resets every time you turn them off (to just use the mist swipe every once in a while or something...).I'll have to try it 7 times, I tested it this morning and it did not come on though I probably didn't do it that many times.
That is the one thing that Dodge has done right, their headlamp/DRL will turn off temporarily while the turn signal is on so it is easy to spot.I notice with my cruze the DRL being the dimmed headlight bulb people can't see my turn signal blinking from the front when turning during the day. I wonder if this is why GM made the 2015 cruze have the separate DRL LED strip?
The reason I know people can't see my turn signal from the front, 99% of the time if I'm turning left onto a side road if a car is sitting there ready to pull out, I flip on my signal early so they will go but they do not get out of my way. Have even had a few of these people flip me the bird.
Tested it today, you are correct, 7 times the wipers pass and then the automatic headlights will switch from daytime to headlights/tails. This also works with intermittent wipers. Learn something new every day!I'll check mine later today - I think it's seven. Make sure you have the wipers on and leave them on, because this resets every time you turn them off (to just use the mist swipe every once in a while or something...).
This a requirement from the NHSTA for all manufacturers. There is a minimum distance the turn signal must be from the DRL or the DRL must shut off when the turn signal comes on. I remember performing a recall on GMC Envoys in the early 2000's to replace the bcm with a new one that shut off the DRLs when the turn signal came on. That's where I learned of the law.That is the one thing that Dodge has done right, their headlamp/DRL will turn off temporarily while the turn signal is on so it is easy to spot.
Which begs the question of why the Cruze doesn't.This a requirement from the NHSTA for all manufacturers. There is a minimum distance the turn signal must be from the DRL or the DRL must shut off when the turn signal comes on.
Not enough people crashed yet?Which begs the question of why the Cruze doesn't.
It is a little more complicated than the distance. If the turn signal is more than 100 mm away no dimming is required. If it is between 60-100 mm no dimming is required if the light uses a reflector and meets a certain brightness ratio. Not sure about the dimensions on the cruze. Here is a link to the law.Which begs the question of why the Cruze doesn't.
After seeing how many people can't see my front turn signal during the day, I suspect this is why the 2015 cruze has a LED strip as the daytime running light. I don't know all the complex rules involved but no way the turn signal being in the same housing as the headlight just up/back 3-6 inches is going to be very visible.Which begs the question of why the Cruze doesn't.
