No clips, just double sided tap to hold it on. If you have a heat gun, or hair dryer will work, lightly heat it up while using a plastic door panel tool to remove, or screwdriver, but be careful with your paint. If replacing with a new one, will need to clean as much of the old tape off before installing new emblem. Also, make sure you only use a GM replacement emblem, the aftermarket ones are junk, and not worth the 5 bucks you save. I have experience with both.
