Thanks for writing this.I finally got around with ordering a new dash camera and installing it on my recently purchased 2017 Cruze hatchback. I couldn't find too many threads about doing this so this will be somewhat of a guide.
So, the camera that I bought is "Rexing V1P 3rd Generation Dual 1080p Full HD Front and Rear 170 Degree Wide Angle Car Dash Cam". I'm not trying to sponsor them in any way, but I had one of their previous models for a couple years and I liked it so I went with one that has a front and rear camera. I figured because I got the hatchback that has somewhat of a good view out the back (partially vertical glass) that a rear camera would work as well. The front camera is the main unit and it has two USB wires coming out of it. One wire is for power and that goes to a cigarette outlet and the other USB cables goes to the rear camera.
I started with the fuse panel that is below the touchscreen unit. There's a handle on that piece of plastic and it pulls right out with just a bit of force.
The back of the panel shows what fuses go where.
I ended up using the 5 amp fuse to the right of that green 30 amp. The chart said that it was blank and I used a fuse tap to keep the 5 amp fuse on the line. I tested it to make sure that it was a "switched" power source. That is when the car is off that fuse is off. This prevents the camera from always running and killing the car battery. This also means the camera automatically turns on when the car turns on.
Here's something very similar to what I used when I say fuse tap.
To get a wire to this location I pulled off this side panel. Just give it a good tug and it will come off really easily because it uses metal clips.
Here's what it looks like with my wire ran.
I kept the stock dash camera wire that uses a cigarette lighter socket and added something very similar to this product.
What happened to the rest of the pics?
Check this out too: [h=1]How-To: Write a Tutorial[/h]
