Is there a particular pattern? Does it do this at a particular volume, when hitting bumps or does it sound like they're about to blow? Have you tried multiple inputs? Cd, fm, Sirius, Bluetooth, and got the same sound? What year and trim is your cruze?Hi there my front speakers on both sides keep cutting out what is the cause?
How long ago did you have them installed? Is it possible the wiring insulation is being worn through due to the way they were installed? What type of connectors did you use? Is it possible they have come loose or were never really put together well?The right front driver side would cut out and then the left side would cut out at times i tried everything the speakers are polk audio 6.5 with tweeters.
