I had the dealer replace the turbo oil feed line (original, pre-heat shield jacket) on my 2012 1.4L Cruze. Oil was starting to seep from the o-rings. $200 for the job.
They mentioned the front timing cover needs to be resealed and want $1,300 for the job. The service advisor said 7 hours for labor and required removal of water pump. I see some crud and seepage near the front of the engine block on the passenger side, near the water pump and the oil dip stick. The general location is similar to the images in this post:
Oil Leak Beside WaterPump? | Chevrolet Cruze Forums (cruzetalk.com)
I didn't see much about this seal failing on the forums and want to confirm if the price estimate / labor charge is reasonable or should I look elsewhere. Thank you in advance!
