Aluminum shifter knobs for sale for the manual transmission Gen1 Cruze. Threaded M10x1.25.
Some Cruzes were threaded M10x1.25, some were press fit. If yours was threaded, this will be a direct replacement for the OEM shift knob. If yours was press fit, you'll need to use a tap & die set and some oil to thread the shaft down to M12 and then again to M10x1.25. All it takes is some elbow grease. You'll need to thread the shaft down by 1".
There are 4 shift knobs left. See attached pictures.
86.2 KB
50.7 KB
77.7 KB
96.7 KB
94.6 KB
89.7 KB
