1 - 9 of 9 Posts
Hey all,
I posted in the DIY fuel filter change thread but would like more eyeballs in case people don't check it.
I attempted to change my fuel filter and was unable to get the cap off. The whole housing is loose and is just hanging in the mounting bracket. Those who have changed their own fuel filters, was this the case on your cars? When I torqued the cap to try and loosen it the housing popped out of the bracket, which is just a flat part on the filter housing that sits in a slot on the frame. Someone mentioned a spanner wrench in another thread, is that mandatory to hold the housing while torquing the cap? Almost seems like it to me based on my car. I'm wondering if something was missed at the factory to secure it, glue or a snap on piece of some sort.
I've never had an issue like that and I've change my fuel filter a few times. Do you have any pics?
Yeah, that doesn't sound at all like my experience. I was initially going to loosen the housing with some vise grips, but the thing was so tight that they started slipping, so I had to run out and get a large socket to fit. Even then I almost had to get a breaker bar to get the thing started. The filter was pretty firmly attached, and the top half, that stays with the vehicle, never moved at all.
COTM Winner
Yeah, that filter took some effort to remove it from the bottom half. The new design should not have that issue.
Well I was able to get it loose. The housing has a clip at the top that clicks into the mount on the car, and it popped loose the first time I tried torquing the cap. With it clicked in it is more secure and not completely bouncing free, but it is not enough to hold the housing alone when trying to get the cap off. I used a spanner wrench to free it but it was quite difficult to loosen. I had to take the cap off again because I had a small leak, and in doing so I broke a couple of the plastic tabs with the spanner wrench and switched to a rubber strap oil filter wrench (similar to this: http://www.amazon.com/RUBBER-WRENCH-Filters-Plumbing-Wrenches/dp/B00BLH9S04 ) from then on and managed to tighten it back up without it leaking. Next time I'll know what I'm dealing with so hopefully it will go smoother.
Glad to hear mission accomplished!
I know this is a old thread, but I had the same issue on my recent filter change. It appears the housing has swelled, or shrunk.. it's just too tight to remove on the car (it pops out of it's plastic mount on the fuel tank). I had to remove the entire assembly, put it in a vice to get it off, and it was still tricky. In the attempt to restrain it under the car with a strap wrench, managed to crack one of the mounding "wings" and had to plastic weld repair that. The new filter went in, and it was difficult to tighten as well, the housing appears to be excessively tight. I even used some slick Teflon grease, and still too tight. I looked at the cost of a new filter housing, about $140, but the Gen 2 housing (Same filter), and only slightly different shape on the cap, was on amazon for $27, I ordered one of the Gen 2 housings, and it will go in next time I need to change that filter.
Gen 2 housing (AC Delco TP1017): https://smile.amazon.com/gp/product/B078TNDR71/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Gen 1 housing (AC Delco TP998):
Reviving an old thread
After owning my 2014 diesel for 26 months, I finally had to change my fuel filter
I also had the issue of a super tight housing cover. I was putting some torque on it with a 12" ratchet and it didn't budge. My Milwaukee M12 stubby 3/8" impact set on full power with a 4.0 battery struggled, but did eventually loosen and remove the housing cover. This same impact can loosen my Cruzes lugnuts. The impact gun has the advantage that all of its force is not just twist like a ratchet is, so the entire housing doesn't try and twist when loosening.
Yeah these are a very poor design. I just take it slow and keep a constant pressure on it. I've done mine twice now and have a 3rd due in a few months. When I re-tighten I take it easy so it's not leaking but still easy to get off next time.
1 - 9 of 9 Posts
