So I'm trying to fix my wife's car, she complained of a fuel smell when at a stop with the heat/AC on.
After a quick look under the hood I found a fuel line leaking back between the engine and the firewall.
If anybody has a PDF version of a IPB or just knows the P/N so I can order a new one that would be much appreciated.
Curious to know if there are more people with this issue? My Cruze has been at the dealership waiting a month for a new fuel line 🙄
I'm having the same issue with the fuel injection pressure dampener(the disc-like thing on the fuel line, near the injectors-so check there). Thankfully I looked while fixing the intake trim arm issue, because although I havent been able to smog it since NOVEMBER, I would rather not die in a ball of fire, in 100+ degree weather.
The part has been on national back order almost as long as the car has been around.
Car is a 15 LS with right at 60k miles on it
[QUOTE="B3trayus, post: 3339619, member:
[/QUOTE]
I ended up with a salvaged part. Could t get a new one
