Why are the o rings different colors? Did you replace them at some point? And what is the best cleaner to use on these?
Why are the o rings different colors? Did you replace them at some point? And what is the best cleaner to use on these?[iurl="http://www.cruzetalk.com/forum/attachment.php?attachmentid=214954&d=1483279471"][/iurl][iurl="http://www.cruzetalk.com/forum/attachment.php?attachmentid=214962&d=1483279513"]
[/iurl]![]()
35,000 miles with EGR pictured above
50,000 miles on delete tune below
[iurl="http://www.cruzetalk.com/forum/attachment.php?attachmentid=214970&d=1483277547"][/iurl][iurl="http://www.cruzetalk.com/forum/attachment.php?attachmentid=214978&d=1483277520"]
[/iurl]![]()
Same o rings. I guess the green coating came off of it.Why are the o rings different colors? Did you replace them at some point?
I wonder if MAF cleaner would work?Same o rings. I guess the green coating came off of it.Why are the o rings different colors? Did you replace them at some point?
I do not know of a recommended cleaner for the sensor. I know carburetor cleaner leaves a lubricant behind when it evaporates which isn't ideal. Brake cleaner works really well but can damage electronic components by removing insulation. Brake cleaners also attack certain plastics and rubber compounds.
I scraped off the big chunks and and wiped the rest off with a paper towel
Did the MAF cleaner work on it?I actually just pulled that sensor and cleaned it. When it came out it looked identical to the pictures you posted bradherr. All 4 of those slots were almost plugged solid with soot. My car has just over 35,000 miles. I would definitely recommend that everyone pull and clean that thing at least every 30k. Unless you're deleted lol. The advantages of deleting these cars just keep piling up.
It did seem to help. I used a pick tool to grab all the big stuff and then sprayed it with that MAF cleaner and it seemed to get to all the stuff I couldn't get to. It cleaned it up pretty good. Probably isn't the strongest stuff but it won't damage the plastic or sensor either.Did the MAF cleaner work on it?I actually just pulled that sensor and cleaned it. When it came out it looked identical to the pictures you posted bradherr. All 4 of those slots were almost plugged solid with soot. My car has just over 35,000 miles. I would definitely recommend that everyone pull and clean that thing at least every 30k. Unless you're deleted lol. The advantages of deleting these cars just keep piling up.
I cleaned mine around 64,000 miles for the first time. Looked pretty much like the dirty pictures above.Why are the o rings different colors? Did you replace them at some point? And what is the best cleaner to use on these?
Take it out at 200k, that is a nice round figure to start from.I wonder what mine looks like after 194K miles.
Pullitoutandtakesomepicstoletusallknow....I wonder what mine looks like after 194K miles.
What browser are you using?Pullitoutandtakesomepicstoletusallknow....
WHY is this mess still happening?!?!?!!? I shouldn't have to retype my comments or anything like that to get the space bar to work properly!!! VERY FRUSTRATING!!!!:$#angry:
I like the info/content of this forum, but the forum itself is severely lacking compared to others I am on!!!!
Pull it out and take some pics to let us all know...
Iamusing...What browser are you using?
I am having the same issues as you as I have the exact same system as you do.Iamusing...
I am using Google Chrome on a PC with Windows 7 Home Premium 64 bit. This is the ONLY forum I have had problems like this on... Like I said, I enjoy the content and like to help people out as much as I can, but compared to other forums this one is a pain in the back side!!!
According to Chrome I am up to date as well...
Version 55.0.2883.87 m
Google Chrome is up to date.
The problem is only here on CruzeTalk though... I am an editor so I am typing/writing all day and my PC is working fin other than this forum, so it is a forum problem not a problem with my PC!!! I just with they would fix/upgrade it...I am having the same issues as you as I have the exact same system as you do.
Might be a pain but if they cant fix it, maybe try another browser for this forum? Just an idea. I use a laptop and an Ipad, and I haven't had any issues, if I use my IPhone it can get a little weird sometimes.Iamusing...
Isurehope...I will report this all to AG. Hopefully they can do something about it.
Old problem, fairly easy fix. Either make sure you're not on the very last character of the text box, or hit A/A button.Pullitoutandtakesomepicstoletusallknow....
