The rear O2 is spec'd at 31 ft/lb according to AllData.
The rear O2 is spec'd at 31 ft/lb according to AllData.Sorry for the delay, no internet at the house.
I do believe it is 7/8 or equivalent metric. Had to use crows foot since my standard O2 socket was not deep enough. Just snugged it down, did not use a torque spec.
Try pulling the O2 sensor and cleaning it, made a very big difference on one of mine.I pulled my MAP sensor last night and cleaned. Needless to say, it was pretty coated with carbon. I personally think it's a crap shoot whether it will make a difference or not. Its just like the people that keep getting repetitive cels and the people that never have one.......it's hit or miss (knock on wood I haven't had one yet). I don't think it can hurt to clean it, that's for sure.
Did you notice any difference in performance/milage.cleaned mine first time today with maf cleaner, was black, but not built up or anything like the egr
I'm still debating on if I want to do mine at all. I've thought about doing it at the same time as the EGR. But unless I'm misunderstanding the sensor, I can't see why being soot covered would hinder it's ability to sense a vacuum. It's not like a MAF where the function is based on airflow.Did you notice any difference in performance/milage.
While trying to decide if it's worth the risk to pull and clean this for the first time at 145k miles, as the original owner. I question is it simply a vacuum/pressure detector why would it extend into the exhaust flow to get sooty.
dont notice a difference.Did you notice any difference in performance/milage.
HiFuel mileage loss, fix = clean the Map Sensor again.
I might just buy a couple of them and replace it every 12 months while cleaning every six months.
I have never had to do such a thing to any other vehicle I have owned. I have never owned a boosted car before.
Cheers.
The EGR I may suggest cleaning...if the MAP gets dirty, the car just won't run ideally...if the EGR sticks closed, it won't start at all.This is an excellent thread with lots of advice and difference of opinions and I have decided to go the "don't fix what is not broken" on my 52k mile diesel.
I think I will do the same with the egr.......
I was following this advice for the MAP sensor ... until I didn't. And I realized I was right, I shouldn't have touched it. Now to see if I can hold out on the EGR.This is an excellent thread with lots of advice and difference of opinions and I have decided to go the "don't fix what is not broken" on my 52k mile diesel.
