This can happen anywhere. Sulfur contamination was the culprit in 2004 in the South with Shell and the Motiva refinery.
“faulty fuel sold by Shell”: “said it has received about 70,000 claims: “figure will easily run into the tens of millions of dollars.”; About 70,000 claims have been filed due to the fuel-quality problem that shut down Shell and Texaco stations in May, but as many as 500,000 people could be affected.; all supplied with the substandard fuel from a Port Everglades terminal operated by Motiva Enterprises…
This could be a faulty fuel sender. As long as the car still runs keep driving but pay attention to your odometer. Unless you just bought this car you should know how far you can go on a tank of gas. If you decide to replace the fuel sender you'll need to replace the main gas pump, which is inside the gas tank.
