Wanted to swap out front sway bar links + bushings to definitively get rid of low-speed front end clunk. The link replacement is well-documented, but I haven't come across any info for accessing or swapping bushings (unless you are dropping entire subframe).
I really didn't want to loosen subframe bolts, as they are TTY and technically should be replaced. Also didn't want to mess with disconnecting steering column. After much toiling (and a few wrenches to the face while working on my back), I can report that the
FSB bushings can be removed/replaced independently of any other system (apart from removing front wheels), though it will be a pain.
The
brackets are slotted front and rear, and tightened down with
13mm bolts. Note that the bracket is mounted with a slight rearward tilt.
The
front bolts are easy enough to access and loosen given the clearance in front of them. I had the engine out, so I just worked from within the engine bay, but should also be accessible by accessing from underneath (via jack stands or lift) or possibly even through wheel well.
Remove these bolts completely.
The rear bolts are the main issue. Given the very tight clearance between them and the firewall above and subframe cross-member that they are mounted to below, it will require ideally a
flat (non-inclined) 13mm closed-end ratchet wrench. Open-wrench is not strong enough to remove, and socket will not even fit over bolt head. One on side, I was lucky that the tightened orientation of the bolt was such that I had just enough rotational clearance with an inclined wrench (slanting down) to knock it loose and continue working it loose a few degrees at a time until I could knock the FSB/slotted bracket forward. However, I was not so lucky on the other side and could not fit the inclined wrench (slanting up or down) over the head; many knuckle scrapes and falling wrenches ensued while trying. I considered using a serpentine belt tool given it's low profile, but am almost positive there wouldn't be enough clearance. Ultimately I used the unofficial Lowe's tool rental program (i.e. buy, use inconspicuously, return
) with a
13mm flat ratchet wrench, which worked amazingly, but didn't want to drop $20 for a one-time use. I just needed the ratchet wrench to loosen the bolt a few degrees, then could continue working it loose with my inclined wrench. There wasn't much rust, and rust penetrant didn't help.
Finally,
removing the old bushings from the brackets/bar is also a pain. The bushing material appears to be a metal/rubber hybrid, but the bushings were seized to the bar (use some silicone spray to loosen) and adhered + clipped into the bracket via some slight tabs that were not recessible. I ultimately got this removed by
hammering a flat head screwdriver between the bushing and bracket or bar and prying from the wheel well. I also was able to split the bushing in half at what was presumably the opening/seam. You can rotate around the bracket/bushing assembly on the bar for more access points.
Old bushings:
New bushings (Moog K200843, ~1" ID, and mate up well to bracket):
