So, I am having some issues on this on an LT1 at just over 1230 total driven. I filled it up fairly well at the last fill up. Considering that the tank holds 15.9 gallons and there are 16 tick marks on the fuel gauge, I was showing about 2 ticks lower on the analog gauge than on the DIC throughout the life of this tank of gas. Ok.
Today at 12.7 used, the low fuel light on, the needle pegged at red, and total to empty going from 41 to low fuel zone, I headed for the pumps with 13.0 used on the DIC. I rolled up with 30mpg and 390 miles driven since last fill indicated.
See where this is going?
So, the pump clicked off at 13.6. I squeezed it up to 13.968 until I could actually see the gas at the top of filler tube.
If we assume that the 13.6 is about right in terms of auto shutoff full values, it seems the fuel totalizing is off by about 5%, which gives me an unhappy moment knowing that actual mpg is thusly overstated by 5%.
That wouldn't be so bad, but 12.5% error on from the fuel sender means more trips to the gas pumps unless I manually compute miles driven against 95% of displayed mpg.
Sorry for the whining, but I'm not happy with anything I just wrote. I've flown 40 year old airplanes that can give me fuel usage down to +/- 0.1 gallons over 75 (just shy of 5 9's accuracy), so my standard for precision is high because the technology to do that is $800 aftermarket. Factory new engineering in present day should be able to do much, much better 87.5%, and for less.
Also is anyone else noticing that the a/c really takea bite out of the mpg. I thought compressors were supposed be much more efficient these days...?
