Wife took the son to Costco had him get out to pump fuel. 2 Gals in she looked in the mirror and freaked out when he had the red gasoline handle in the filler. Stopped him and had him finish filling the tank with diesel. She called before doing anything else. Had her get it pushed into a parking spot. Wasn't started but key switch was probably cycled a half dozen times between getting pushed away from the pump and on and off the wrecker to get it home.
Plan is to drain/siphon what I can and refill with fresh diesel. Depending how much I get out I might do it twice cycling the key a bunch of times to flush what I can through the lines. Maybe change the fuel filter if I can get one local. Also maybe add some stanadyne treatment.
Any thoughts.
2014 CTD 2.0
Fleece delete installed so not concerned about damaging the DPF.
Any thoughts.
2014 CTD 2.0
