Hi
A few times now (but not all the time?) when I have a steady, slight throttle opening between 30 and 50mph, the gearbox goes a bit whacky; unable to make a decision between two gears. It'll change down, rev, realise it's too low a gear, change up; the torque converter will slip a little and then it'll change down again. Rinse and repeat.
Is there anything I can tweak to help back this off? Maybe widen the gap between "I need to change up" and "I need to change down"?
Thanks in advance.
Thanks in advance.
