1 - 4 of 4 Posts
Just put a boost gauge in on my 14 1.4T......Tapped into the green and black like below the manifold like everyone says to do and I'm reading under full acceleration 10-12 psi of boost. Is this normal or do I have a leak somewher? Vacume is 20-22.
I have monitored mine with the Torque app. Mine goes up to about 12, and sometimes as high as 16 when taking off from a stop. When I am on the freeway going about 65 and hit the gas, mine can go as high as 23.
Depends on your location.
Those at sea level will get higher boost then us that live in the mountains. Atmospheric pressure is higher.
If you're getting 20 - 22 vacuum. You're probably in good shape. 21 is the highest at my altitude.
1 - 4 of 4 Posts
