2016+ Gen 2 Cruze MTech Short Shifter
This MTech Q2-Shift is designed for the newer model M20 and M32 Transmissions which are fitted with the upgraded shifter shaft (All Opel/Vauxhall and Chevrolet cars from model year 2016/2017).
A real power shifter which reduces shift times, so up coming gears can be engaged faster. By fitting this shift linkage you will have a gear throw shortening of about 25%. The factory gear stick model and height remains unchanged. The short shifter will be fitted on top of the gearbox where the shift linkage is located. Gear changes are much quicker and precise.
One of the must have modifications to your car!
Shifting with this Q2 Short shifter feels almost like a rally sequential gearbox, "click-clack"
Features:
Features:
[HR][/HR]
- Improves performance
- Faster Shifting
- Made and designed in the Netherlands by MTech
- 25% Shortened gear throw
- Easy to install and operate
- Made from very high quality tensile steel
- Hardened inner parts
- MTech Red powder coating
- Completely reversible to stock
- No modification necessary to the gear shifter.
- No re-adjustments required
- No special tools required
