1 - 3 of 3 Posts
I went through the tutorials in this section and tried to group them in a functional pattern. Normally I start at the front of the car and go back, but in this case I grouped by general categories for now.. If you think there might be a better way to group items, I'm all ears. If you add a new tutorial and I don't catch it, post a note here so I can add it to the list. You might see duplicates from time to time and that is because to me they belong in a few categories.
Brake System:
How-To: Replace Front Brake Pads & Rotors
DIY how to replace brake pads
DIY Flush Brake Fluid
DIY How to replace Brake Vacuum Booster Pump and Pipe
How to: Replace rear e-brake cables (inside the car)
How to Adjust Rear Drum Brakes
Not exactly a How-To:, but info for when you upgrade your Brakes:
Add Brembo Calipers to a car
Alignment:
DIY - Alignment - adjusting front toe
Suspension:
How-To: Install Whiteline BHR93 Rear Sway Bar (2011-2016.5 Cruze)
How-To: Install 2011-2016 Cruze Ultra Racing Rear Lower Bar
How-To: Replace Sway/Anti-Roll Bar End Links
How To: Replace Upper Strut Mount Bearings.
HowTo: Install a front upper Ultra Racing strut bar
How-To: Upgrade to Whiteline Control Arm Bushings
KSport Coilover Install - Picture HEAVY!!!
How-To install coilovers (front=no pics, rear=pics)
Wheels/Tires/Rims:
How-to: Change a Front Wheel Bearing or Lug Stud (no pictures, camera died)
How to match TPMS sensors after tire rotation *
*Cross posted from other categories
1 - 3 of 3 Posts
