1 - 3 of 3 Posts
I went through the tutorials in this section and tried to group them in a functional pattern. In general I started at the front of the car and went back. If you think there might be a better way to group items, I'm all ears. If you add a new tutorial and I don't catch it, post a note here so I can add it to the list. You might see duplicates from time to time and that is because to me they belong in a few categories.
Gen I Diesel Specific Tutorial TOC
Other Underhood:
How-To: Replace the Valve/Camshaft Cover (1.4L Turbo)
How to clean engine bay
DIY Bone chilling AC
Air Intake:
DIY Delete Air Intake Resonator (Pic heavy)
How to: Free filter mod
How To Bypass the Intake Resonator
Injen Cold Air Intake Install
How To: Injen Intake Installation Steps / Pics
Cooling System:
How-To: 2011-2016 Cruze Antifreeze/Coolant Flush
How-To: Replace 2011-2016 Cruze 1.4L Coolant/Water Outlet
How-To: Replace Thermostat Housing & Thermostat (1.8L)
DIY Video - Coolant vent tube to reduce coolant smell/vapor
How To: Change the Water Pump on 1.4 Turbo Cruze
Oil System:
How-To: Cruze Oil Change - 1.4T
How-To: Bypass Filtration Install (1.4L Turbo)
2012 cruze eco manual, oil pan plug, M14-1.5
How-To: Replace Turbo Oil Feed Line
DIY - Oil Pan Heater Thermostat Removal
How to Add a Catch Can to your 2.0 CTD
Fuel System:
How To: 15.6 Gallons into Eco MT Tank
Ignition System:
Shaking rattling spark plug cover
DIY re-gap factory spark plugs
DIY Spark Plug Resistor Bypass (Supersparks)
How-To: Install DDMWorks Throttle Body Spacer 1.4L Turbo
How-To: GM 1.4L LUV/LUJ PCV Fix Kit V1 Install
How-To: GM 1.4L LUV/LUJ PCV Fix Kit V2 Install
Cruze/Sonic 1.4L Turbo LUV/LUJ Timing Adjustment
How-To: Set Timing on 1.4L Turbo Internal Engine Video
How-To: Replace Serpentine Belt 1.4L Turbo
Timing Belt 1.8L and 1.6L
How-To: Remove 2011-2016 Cruze 1.4L Intake Manifold
How To: Replace CPASV (Camshaft Position Actuator Solenoid Valve) Seals
Exhaust System:
How-To: Replace Downstream Oxygen Sensor
How-To: ZZP O2 and Midpipe Installation
Magnaflow Dual Exhaust DIY (RS Model)PICS!!!
How-To: Forge BOV/BPV Installation
Transmission:
Fixed leaking tranny cooler lines for 6 bucks!
How to: Automatic Transmission Fluid Flush
How to change the automatic transmission cooler lines
Trans Fluid How-To
How-To: Change the Manual Transmission Fluid
How-To: Replace Clutch Fluid
MT removal/Clutch Replacement
How To: Remove Clutch Delay Valve (CDV)
How-To: Install Clutch Accumulator Bypass Mod
How To: 6T45 Trans Pump, bell housing Seal, & Filter
How To Install MTECH M32 Short Shifter
DIY short shifter
How-To: bypass your clutch switch *
Pillars and gauges:
How to install Oil Press gauge sensor to/with OEM Oil Sender
How To: Install DDMWorks Throttle Body Spacer 1.4L Turbo
*Cross posted from other categories
1 - 3 of 3 Posts
