I made my own panel. I used a 1/8" heavy plastic sheeting. I used the old door as a template, drilled the bolt holes (make sure they were wide enough to allow movement needed. I then cut the front at a size so it would be able to be inserted into the front edge of the floor pan. I had previously tried it with some thin aluminum flashing but it was two thin to deal with the wind drag and would buckle to the point that the leading edge.
So far so good. I will try and take some pictures with the next oil change.
