1 - 9 of 9 Posts
Welcome Aboard!:welcome:
You need to give us much more information.
[h=2]Fix my Cruze!!![/h]
We want to help you fix your Cruze as quickly as possible. To do that, we need some basic information, such as:
1. Year, trim level, and transmission.
2. Miles on the car!!!
3. Check engine light, airbag, or other warning light on or "Service [insert system here]" message showing? Has somebody told you the code if the check engine light is on?
4. Approximate location of the issue.
5. As detailed a description of the problem as you can give. Something like "My 2012 Cruze Eco manual transmission with 50k miles on it is making a grinding noise from around the brake pedal at 12 mph every time I start the car, and doesn't do it again until I start the car again" is enough to let us get started. (Hint: I described the ABS self-check, and that check is normal for every Cruze on startup)
6. Country! Your warranty and repair options might be different in other countries than here in the United States or Canada.
7. (as needed): Left-hand drive or right-hand drive? If your car is right-hand drive, that's nice to know since a lot of us on this board have little experience with RHD cars.
Lastly, please be patient and polite! All the folks on this board are doing this in their spare time for free, so we might not be able to reply immediately.
(Stolen from Sciphi's post)​
Have you removed it for some reason? Have you tried just gently squeezing it back together?
2017 Glove Box.png 2017 Glove Box 2.png Glove Box Assembly - GM (84035536)
This has a couple of good pics: 2017 chevy cruze cabin filter
This is for a Gen I, but may help: Chevrolet Cruze Glove Box Removal / Replacement
Shucks. This problem was from a year ago and no one offered up any help other than "gently squeeze it back"? I can tell you, that didn't work for me. My glovebox cover did the same thing. My entire cover came off, not just a corner of it like the OP (although I think that may have been how it started).
It's like it was glued and gave way, but there's nothing really in the way of glue residue. A year later, has anyone else had experience with this and did you glue it back or replace the entire door?
It would be very easy to replace it if you cannot figure out how to glue it back together. Just pick one up from a Pick N Pull or LKQ yard. Most of these yards only care about the major parts, so if you buy something larger, the plastic bits are usually free.
And since you seem to be critical of the help offered for a seldom seen problem, I hope you come back and give us a solution. Everyone including the CruzeTalk administrators are volunteers. That means this forum is basically self help. If you are lucky someone knows about what you need or even better yet, they have written a tutorial.
[h=1]How-To: Write a Tutorial[/h]
1 - 9 of 9 Posts
