So do you have an idea where the leak may be coming from - reference the video.Just because the nipple is there doesn't mean it doesn't leak, or that it's not cracked behind.
Sent from my BlackBerry Key2 using Tapatalk
Can't tell from the video but it's a huge leak. Start spraying everything in the engine bay with soapy water and see where it starts bubbling.So do you have an idea where the leak may be coming from - reference the video.
It occurs when I hit 13-17 psi, but only with constant pressure. When I drive it only happens on occasion and I can tell because the engine bogs a bit.Can't tell from the video but it's a huge leak. Start spraying everything in the engine bay with soapy water and see where it starts bubbling.
Hi Blasirl,It occurs when I hit 13-17 psi, but only with constant pressure. When I drive it only happens on occasion and I can tell because the engine bogs a bit.
On my second try, I did spray soapy water and no bubbles. It does get louder as get closer to the bottom of the throttle body spacer though as seen at about 2:20-2:30
I know this is older than dirt, but it just occurred to me that you could possibly use a portable air tank with the hose modified to attach to the leak tester. I bought mine from Menards for $20 or so.Unfortunately, not all of us are in a position to have a compressor. Is this something that could work with a small tire pump? Perhaps one of those small ones powered from the cigarette lighter?
Yeah I'm amazed how many places it was (and still is to a degree) leaking.Good to hear its helping you to find these, mine has came in real handy!
