641 - 647 of 647 Posts
Discussion Starter #642
XtremeRevolution....My 16 Limited has 31k miles on it. I have no CEL or weird smells and purrs like a kitten. I would however want some peace and mind but doing the V3 kit before it all goes south. What would you recommend? Is it possible to install the kit without a failed PVC system. Thanks.
It is possible. You have to break the tip off the old check valve first in order to install it, with a flathead screwdriver. After that, you can just install the kit with nothing else needed.
Sent from my BlackBerry Key2 using Tapatalk
I see, wh
When will the V3 kit be available? I dont see it on your site, it seems to be the easiest way without taking the motor apart. Id like to order it ASAP.
Discussion Starter #645
I see, wh
It's on the site. Last product on the list.
You have to use an ampersand before the name to make the tag work - but to answer your question, you can install the kit without worry about causing more issues. As a caveat to that, any time you start twisting hoses, stressing plastic connections etc, you still run the risk of creating more issues, but all of them are easily fixable. So I would install the kit myself.
