My GM performance brake kit just came in, and I have to mention this in case anyone else is thinking about buying it. IT DOES NOT INCLUDE REAR ROTORS! They do not make this clear on the website.
From the chevrolet accessories website:
Front and Rear Brake Upgrade System in Red
Helps enhance your vehicle’s brake performance
Helps minimize brake wear under high performance driving conditions
Replaces the brake rotors, calipers and pads
Description
Help enhance the braking performance of your vehicle with this Chevrolet Performance Brake Upgrade Package. These performance brakes are for those looking for ultimate braking performance while maintaining street drivability. The kit includes front and rear brake pads, seals, rear brake pad springs, power brake booster assembly, master cylinder seal, master cylinder nuts, and brake pedal push rod retainer. The Duralife™ rotors feature a hardened surface to reduce corrosion and provide quieter braking with less vibration.
As you can see, everything implies it includes rear rotors as well. It has front and rear pads, front and rear calipers, front rotors ONLY, rotor shields, and replacement bolts.
I have not installed it yet, so I can't speak to the performance of the new parts. I will be installing them today if the local parts store has replacement rotors for the rear.
Description
