Basically my car exhibited the symptoms @ 61K miles but before this recall. Since the problems developed after the first recall was recalled by the second recall with no recall left in place at the time, I paid out of pocket. Seems I should be asking to be reimbursed under this new recall.Has anyone had this recall done (replace the NOx position 1 sensor and reprogram the engine control module with a modified calibration, and initiate a Diesel Particulate Filter cleaning cycle)? if so, how's the car running?
Usually they send out a letter for things like this like with the water pumps on 1.4 gas to submit for reimbursement if you can find the receipts. I would hope they step in and help keep their customers in their cars and brand at least.Basically my car exhibited the symptoms @ 61K miles but before this recall. Since the problems developed after the first recall was recalled by the second recall with no recall left in place at the time, I paid out of pocket. Seems I should be asking to be reimbursed under this new recall.
The car has has been running fine for the last 2K miles, no codes.
Over my first 47,000 miles I had 90 regens or about every 550 miles. over the last 1000 miles I had six regen (about every 166 miles). Seriously considering the recall. Let us know how your goesMost likely going to have this recall performed on Tuesday. Bringing my car in to the dealer to get the broken turn signal reflector in the headlight housing fixed.
Right now my vehicle is going through regens every 160 miles so hopefully this will fix that! Will report back.
Let us know if you are getting increase RGN frequencies now post- recall. I started at 0 STM and after 40 miles it is at now 14 STM (Total Soot Mass) according to my ScanGuage II.Had both done. Latest one today. No ill effects from the first one and don't expect any from this one. I'll report back later on it
Ha I just had the same thing done, only drivers side headlight.Most likely going to have this recall performed on Tuesday. Bringing my car in to the dealer to get the broken turn signal reflector in the headlight housing fixed.
I bought a used CTD with 63K miles...Is there a website where I can type in my VIN to find out what recalls/updates have been done? Or is my only option to stop by a dealership and run the VIN?
Thanks Cruzator, very cool!!IF you set up an account and log in, it will tell you about the extended warranties that have been issued as well (negative battery cable, def heater, etc.).
