Well, it has warmed up... the car has 23k miles on it. It drove a few minutes ago and it shifted just fine.Just don't tell them you have AMSOil in the gearbox. If they have to replace the fluid under warranty they are required by GM to use the GM synchromesh. This really sounds like a worn clutch to me.
I wonder if the linkages between the shifter in the cabin and the transmission need to be adjusted and relubricated. We've had a few members have issues with shifting and the problem was improper alignment between the gear shift and the transmission.Well, it has warmed up... the car has 23k miles on it. It drove a few minutes ago and it shifted just fine.
I could see this issue reared its head if it was -20F, but not at 30F. Right now I'm leaning towards going back to GM synchromesh and see if it corrects the problem. If not, then maybe I can get some help from the dealer since it is still under bumper to bumper.
