If you have a Gen 1 CTD, the tank WILL hold over 18 gallons...you just need to be very patient.How are you putting 18 gallons in? Mine clicks off at about 14.5. I can maybe squeeze in another .5 gallons till it at the neck. I've had the low fuel light on and put 50 more miles on before getting gas and it still barely makes it over 15.
You're going to have to wear plastic gloves on that one ( if you don't want smelly hands , that is)....I carry a box of the nurses-type gloves in the car. Cheap at Costco or SAMs.This guy says covering the vent hole on the fuel nozzle eliminates foaming. I think that's the hole that also tells it when to click off so you have to be careful. In their forums he said if you just do about 1/2 flow you can cover the hole without stopping it from clicking off.
https://www.youtube.com/watch?v=AB082zQ7Das
The place I fill up has plastic gloves out by the diesel pump, thankfully. I thought I read somewhere that overfilling the tank will cause damage. I wonder if the foaming is considered when they are planning tank capacity and sending unit design.You're going to have to wear plastic gloves on that one ( if you don't want smelly hands , that is)....I carry a box of the nurses-type gloves in the car. Cheap at Costco or SAMs.
Yeah I tried that “cover-the-hole” technique a few months ago, didn’t work for me at all...made no difference with the foaming.The place I fill up has plastic gloves out by the diesel pump, thankfully. I thought I read somewhere that overfilling the tank will cause damage. I wonder if the foaming is considered when they are planning tank capacity and sending unit design.
Hmm interesting, know what the difference is?Yeah I tried that “cover-the-hole” technique a few months ago, didn’t work for me at all...made no difference with the foaming.
I’ve been topping my diesel to the rim for a year with no adverse effects whatsoever. My understanding is this should NOT be done with gasoline vehicles but OK for diesels.
It has a few enhancements plus a few mods.
Tire pressures are maxed out, 55-58 psi warm.
Grill block off ran below 65°f
Partial extended belly pan between rear axle and rear bumper
Amsoil full synthetic fluids throughout power train
Pretty rowdy tune in computer
Removed extra parts and pieces to reduce weight
It sounds like you might be filling the vapor space.If you have a Gen 1 CTD, the tank WILL hold over 18 gallons...you just need to be very patient.
When diesel fuel comes out of the pump it foams. That foam creeps up the fill pipe and clicks off the pump.
To truly “top off” your tank to the very end of the fill pipe, you have to keep clicking the pump on very slowly till the foam reaches the top, stop for 10-15 seconds and repeat. This process will go on for about 10 minutes.
Eventually the diesel level will reach the top of the fill pipe and you will visibly see diesel (not foam) level with the fill pipe opening.
My experience has been that the point at which diesel fuel pumps click off varies from station to station. But generally after the pump clicks off on the Gen 1 CTD, you can get another 2-3 gallons into the tank/fill pipe.
That can equate to another 100-150 miles of range on a filler-up!
(added note: 18+ gallons would be achieved only after running the tank down about 60-80 miles PAST the Low Fuel light)
That's what she said.....It sounds like you might be filling the vapor space.
Yes, that is what is happening. Running the tank that high can damage the evap system. However, it is possible that due to the nature of diesel foaming that GM built the tank to allow fuel to run up over the evap valve and not cause issues.It sounds like you might be filling the vapor space.
