Which wire do I use for a remote turn on wire for my aftermarket amp in a 2017 Cruze LT non BOSE. I need a wire that doesn’t turn the amp off when the auto stop start restarts the engine. I am amplifying the door speakers with this amp and not just adding a sub. Does anybody know. I had a 2017 Malibu LS and that had a amp in the trunk non BOSE but it still had a separate amp and it had a wire where you could tap into for a aftermarket amps remote wire whereas if you didn’t use that wire the auto stop start would make the amp turn off and on real quick as the engine restarted so I’m trying to avoid that with the Cruze. Any help?
