They wouldn't be lieing about the front.
No idea on the rear.
Harborfreight sells the spring compressor tool although no one in the truck forum seems to know how to use it properly.
You can also buy struts with the springs already installed which would be the better way to go. You get new springs and mounts that way.
BTW. I watched a kid slice off his nose and front teeth and toes taking the strut off a car improperly. He didn't pull the entire assembly out first and compress the spring. He took it apart inside the car.
The strut rocketed to his feet and cut off his toes. The spring hit the the rotor and ricochet up his face and through the ceiling. Shoved his front teeth in to his skull and sliced off his nose.
