Grinding/Rattling/Buzzing noise from A/C
11955 15
Hi all,
I've got a 2013 LT 1.4L AT with 85K (recently bought it used at 82K over the winter) and every time I turn the A/C I get some pretty loud rattling/buzzing sound(s) from the engine compartment. It's mostly noticeable when I'm stopped at a light in-gear. It seems to lessen ever so slightly when I drop it into Neutral - but it's still quite noticeable. Is this a common/known issue with some part of the Gen I A/C system? If so, can someone tell me what that part might be? Thanks
1 - 16 of 16 Posts
Nope, never heard this one.
If it only happens with the AC compressor engaged, look to the engine fan or compressor.
If it happens ANY time the cabin fan is on, pull out the cabin filter and look for debris that has fallen down into the blower cage.
2016 Cruze Limited LT
Hi all,
Not sure if it's the same issue, but I was getting some buzzing noise when my AC was on was recommended to check the cabin air filter, I pulled it out clean off all the leaves and debris and haven't had the noise since so worth a shot and only takes 5 minutes to look. Hope it helps
If it disappears when your rev it slightly, I'd take a look under the hood. It might just be something rattling (perhaps a heat shield) and it's related to the exact engine speed when the A/C is on and not anything to do with the A/C itself.
Then again, it might be the belt tensioner starting to go.
...and every time I turn the A/C I get some pretty loud rattling/buzzing sound(s) from the engine compartment.
Have you gotten under the hood and tried to pinpoint the source? If the noise starts when you turn on the AC, it could be coming from the cooling fan on the radiator or from the AC compressor. As suggested herein, it could be a belt tensioner - the load on the belt increases when the AC compressor kicks in.
The cabin fan could sound like it's coming from under the hood. Does the sound change when you change the fan speed with the AC controls?
This is puzzling. Normally, the engine speed will go up slightly when you shift from drive into neutral. If the noise is tied to engine speed, I would expect it to get louder, not softer, when you shift to neutral.
One other thought - the system voltage will vary slightly with engine speed. Depending on the regulator (and whatever charging mode is in effect), the system voltage could go up slightly or go down slightly when the engine speed changes - the voltage regulation won't be perfect. So, when you pop it into neutral and the idle speed goes up a bit, I could see the system voltage going down slightly which in turn could cause a noisy fan to slow slightly. I may be stretching things a bit to get here, but I can't come up with any other explanation why the noise gets softer when you put it in neutral (unless it's coming from the transaxle, in which case it's not tied to the AC).
HTH.
Doug
Thanks for the input guys. I have to admit, I haven't opened the hood to investigate it when I get home. Just started using the A/C a couple weeks ago and by the time I get home, I just want to get in the house and get other things done so I forget to check it. I can say it's only when the A/C is on and not just fan - so I'm guessing it's not the cabin air filter. And the sound seems to go away (or I just hear it a lot less) once I start moving again. I'm thinkin' either compressor or tensioner or something like that. I'll try to dig deeper this weekend and see what I can find.
Not that uncommon in cars (in general). Something is loose under the hood and it vibrates at an exact RPM. Putting it in neutral shifts the RPM just enough so it won't vibrate as much. Heat shields are frequent culprits - large chunks of thin metal bolted down in only a few spots.
But it could be something on the drive belt. It might be worth popping the belt off and giving things a spin by hand to make sure the bearings in the water pump, alternator and tensioner are not "crunching".
I saw the heat shield reference _after_ I posted :eek: I have heard things resonating in the exhaust before, and you are correct - a little shift in RPM's will make it go away.
Doug
I
My daughter just bought a 2014 1LT with 120K on the clock. She brought it over to me and stated her it is making a horrible rattle noise with the A/C on. He problem is exactly the same as the OP. I found the noise would change when I pried on the A/C compressor. I removed the air filter box, belt, and then unbolted the A/C compressor and laid it to the side. I checked the 3 bolts that hold the A/C compressor bracket to the engine block. I found the front top bolt completely backed out and just sitting in the hole. I checked the torque on the other bolts they were tight. I applied red lock-tite to the bracket bolt threads and reinstalled. Torqued to spec and then reinstalled the A/C compressor and all removed parts. I started the engine and the noise is gone. It is a pretty straight forward repair. Took about 45 minutes from start to finish and 1 beer. Cheers!🍻
2013 Chevy Cruze LT RS - Atlantis Blue Metallic. This color is growing on me, miss my black LTZ-RS
This, my latest Cruze was doing the same thing. The compressor's bolts were all finger tight. Tightened them up, no noise.
Hi all,
Hi all,
My wife’s car is having the exact same problem. She just turned 80K in it. I’m mechanically inclined but this one has got my stumped. I cannot pin point when the noise is coming from. My first thought was the motor fan but it seems to get loud as I move my head closer to the firewall and if I set my hand on the back of the valve cover (Over injectors) it feels like that’s where the vibration/noise is strongest. It stops when the A/C is turned off and doesn’t do it when running just air so it’s not cabin blower fan debris. The noise is worst when in gear and stopped. Seems to stop/lessen when put into park or when driving. Hopefully the added details can help someone to help me identify issue.
Unplug the purge valve at the back of the motor and see if it stops. It will throw a code, but easily reset.
1 - 16 of 16 Posts
