1 - 10 of 10 Posts
Got the GTR Ultra Gen 2 bulbs installed today. Not quite plug and play but still easy enough to do.
First off the factory 9005 Halogen bulb pics at night, low and high beams, against a wall and looking out across my back yard.
284922
284923
284924
284925
OEM Halogen:
284926
GTR Ultra Series 2:
284927
Now the problems. The heatsink and fan on the GTR sticks out farther than the factory bulb and requires a little modification to the dust cover. You can see here where it's hitting on the sloped part:
284928
There's this tab that makes it so the cover can only go on in one position:
284929
First step is to cut this tab off. I just used a small hacksaw.
284930
With that gone you can rotate the cover 180º and get the sloped part out of the way of the heatsink. It still hits but much less than before.
284931
Discussion Starter · #2 ·
So I just took a heat gun and softened that area inside and out then used the back of a screwdriver handle to push the plastic out to give clearance. It doesn't need much, less than 1/8"
284932
284933
Boom. Perfect non-interference fit.
And an after install pic:
284934
I'll get some new night shots hopefully tonight and post them up. I also need to return the GTR PWM modules to Headlight Revolution as they're not needed.
As promised here's the night shots with the LED's. The difference is INSANE
284941
284942
284943
284944
Reactions: Iamantman
Very nice. I also had the same problem with the caps not fitting when I installed my Fluxbeam LED bulbs. Unfortunately, I did not modify them to fit, and now I have a moth stuck in the housing until it dries up and falls away lol
Oh look, the exact same pic you posted TWICE over on Jalopnik. IDGAF if their lux meter reads high. Proof is in the pudding. They're brighter, throw more light to the sides and have the same glare/cutoff as factory.
And I replied to your "old bulbs" comment to which you never responded. The car only had ~10k miles on it when I did the swap and the bulbs were hardly even used (at least by me in the ~4k I put on it) so the bulbs were not old and worn and dimmed out.
How hot of a heat gun do you need to do be able to push the plastic back?
You could probably do it with a hair dryer honestly. I have a cheap Harbor Freight heat gun that I've had for years and used it on low setting. Just heat it evenly and don't bulge it more than you need to. It doesn't take much.
1 - 10 of 10 Posts
