If you are not moving more than likely it is not the harness. If the lamp is connected to something that has a large current draw and that something cycles it could be that.
You can get a fair idea if the resister is the correct size by measuring the resistance across it.
It is more than likely that it is a bad connection, but it could be the lamp as well.
There's a glare in the headlight cover that looks like it's coming from the headlight. Yet I can see the headlight flickering. I suspect it means you have a bad bulb.
Are both sides doing this or just one?
I'd start checking the warranty.
just driver side
