1 - 3 of 3 Posts
My 2011 Chevy Cruze LT has been a very dependable vehicle. However, recently it has started to fall hard into second gear after it has been running for about 20mins or so. I received a clear diagnostic report from a reputable transmission shop so I am looking for similar occurrences from other Cruze owners or possible remedy suggestions. Also zero codes and or check engine lights. Thank you!
The 2011 transmissions are known for issues.
If the fluid has never been changed or the level checked, this is absolutely a good place to start. The cooler lines and sometimes axle seals are prone to leaking; low/dirty fluid will cause harsh shifting and other engagement issues.
1 - 3 of 3 Posts
