Because GM does not want the liability when you squash your kids head in the back window.All of the windows automatically go down but why does the driver window only automatically go up ?
Welcome Aboard!Thanks guyz !
Not really. Although there is a heat exchanger in the radiator to warm it up (and then a cooler to cool it down), it lags quite a bit behind coolant temp.Stupid question:
2012 eco AT
Is the DIC display engine coolant temp a good indicator of transmission fluid temperature when checking AT fluid level? 185-203F AT fluid temp I've read.
Thanks CT!
From what I've read online, the average life-span for the cruze 2012 is around 130,000, so I'm mainly just going on assumptionsWhat makes you think that?
IdFrom what I've read online, the average life-span for the cruze 2012 is around 130,000, so I'm mainly just going on assumptions
Good maintenance and addressing issues before they become a major issue (PCV, cooling system parts, transmission fluid) is key to a Cruzen living a long, happy life.I'm new and I got a question, not sure if it was asked yet:
My 2012 Cruze is getting up there with 87k+ miles, and I know that time may be coming in a few years when I'll need to swap/fix the engine or transmission.
Is it worth swapping the engine/transmission when they break? Or should I look towards a new model?
(This is my first economic car btw)
The trans fluid was just changed about 1500 miles ago. I guess ill order the clutch byepass and remove the delay valve.Cruze Manual Transmission (M32) Issues
How-To: Change the Manual Transmission Fluid
How-To: Install Clutch Accumulator Bypass Mod
Gen1 Cruze Clutch and Manual Transmission Shifting Upgrades
How-To: Remove Clutch Delay Valve (CDV)
How-To: Replace Clutch Fluid
AMSOIL 75W-90 GL-4 Manual Transmission Fluid
AMSOIL Products for the 2011-2015, 2016 Limited Gen1 Cruze
Thread 'Manual Transmission Specs!'![]()
M20 & M32 Gearbox: Chocolate Bearings - Still Running Strong
The ULTIMATE GUIDE to the infamous M32 gearbox. Learn everything about bearing failures in the M32 and M20 gearboxes - Causes, Symptoms & Repairs.stillrunningstrong.com
The programmed rev hang (annoying in itself) is basically non existent with the AC on. RPMs dump like a brick on higher fan speeds, which makes for a not-smooth clutch release, and we all know these cars hurt for low RPM power too with the AC running.Why does my car shift different when the air conditioning is on ? I hate the way this car shifts I cant wait to get the clutch byepass. Its to the point where I dont want to drive the car much anymore. 1st gear to second makes a noise sometimes.
