This should help
This is the tightening sequence, right? Do you also happen to have the torque settings?This should help
Thank you!I do have torque specs. Will post them when I get a min in the morning
I got new onesNote to OP......these are torque to yield, one time use head bolts.......that is why the 180 degree spec after initial torque.
The 180 degree turn causes the bolt to stretch.
I know, old post but for everybody else that is looking for this info: That photo is of the way they recommend you "loosen" the head bolts, an inward spiral. For tightening you start in the center and spiral outwards. This is true for all makes and models.This is the tightening sequence, right? Do you also happen to have the torque settings?
Thanks for posting this information. I've looked all over for torque specs. I bought some manual from ebay to no avail. Helms manual is 510 dollars. I bought the Chilton's book and the Chilton folks should be embarrassed for what they publish today vs 30 years ago. They are less informative than comic books I knew something was fishy as they torquing the head bolts outside in !!I know, old post but for everybody else that is looking for this info: That photo is of the way they recommend you "loosen" the head bolts, an inward spiral. For tightening you start in the center and spiral outwards. This is true for all makes and models.
