Hey.
So basically I have a leaky head gasket. Some Lucas Oil stop leak was used along with "Block Repair" in the coolant and so far it's not performing bad but I still don't have correct compression in 3&4.
I'll be replacing the head gasket, myself.
Anyone ever done this and do you have any tips? Anything, in particular, that was difficult?
Hey.
I have not on this particular engine. But make sure you get out as much of that "block repair" **** than as you can. That stuff will ruin the cooling system if it hasn't already. Your radiator and heater core are probably full of that stuff.
I apologize if this qualifies as post bumping, but I'd like to share my insight and experience.
I've done the job on my 1.4T Cruze and it spanned 4 and 1/2 months of general carefulness and lack of motivation. It can definitely be accomplished in under that time-frame.
Pick up a Hayne's Manual for your Cruze. It includes procedures for all 3 motors offered in the States.
One thing I strongly urge you do is appropriately label and separate the bolts and parts that are being reused on the car.
Taking pictures of bolts, parts locations and wire harness couplers will help tremendously.
-Obviously never ever reuse cylinder head bolts as they are Torque-to-Yield.
-The engine room harness branches that lay in view of the valve cover should be moved out of the way, which will require disconnecting a number of couplers.
Remember, take pictures before unplugging something.
-There will still be fuel left in the fuel rail after removing it. Be careful not to accidentally pour gasoline on your favorite shirt 2 hours before your shift at work.
-Removing the corrugated PCV hose on the turbo and intake manifold may end with it breaking. I mean, either way you'll get it off.
You can find a replacement here: https://www.amazon.com/ACDelco-25193343-Original-Equipment-Ventilation/dp/B010GOPTPU
Or, if you wish to go a different route: Corrugated PCV Hose Replacement/Upgrade
-Removing the turbocharger can be done without removing the catalytic converter from the exhaust system. Just be careful not to snap the clamp that keeps the exhaust side of the turbocharger sealed to the catalytic converter.
-Go ahead and order this timing kit: https://www.amazon.com/YOTOO-Turbo-...uze+1.4+timing+tool+kit&qid=1609221903&sr=8-5
One of the smaller pins are used to lock the tensioner in a fully compressed state. Not only does this provide slack in the chain, but clearance for the tensioner so that you don't run into a snag while getting the cylinder head off.
If you have any questions or need advice don't be afraid to keep replying here. We're more than happy to help you tackle this job so you can get your Cruze running again
how about you snap some pics of the procedure and post them here instead of buying a manual.
