I rebuilt my engine with Vtuner forged pistons and Valve Springs.
Had to send the head to a machine shop to press in new seals as overheated my two inner most exhaust valve seals. They put in new springs free of charge upon full head rebuild @ $800 (Candian rupples)
Needed these tools, rented a good ring compressor for free, 20 hours of self labor
Freedom AM-49977 Engine Timing Tool Kit for 1.4L
Challenging points:
Engine needs to be suspended to access front cover, used a cheap Come-A-Long Winch to the roof to hold engine.
Needed a plastic gasket removal tool & Solvent to clean block surfaces
Keeping your stick on the Ice
Other notes:
Did the rebuild around 75k miles
Use oem piston rings, they are very strong, made in germany, they come pre-gapped
Do not bore sleaves! I ran over 2000F and my sleeves were mint. Could see original machining lines, no TDC lip!
Boring your sleeves will require custom pistons/rings
Stock Cams are ideal.
Stock Rods are Forged
Loosen the radiator to get more working area in the engine bay.
Able to do rebuild with block in engine bay, car on ramps
