Headlight Bulbs
2496 11
Anyone can recommend really good bulbs? I don't want HID conversion. Currently, I do have L.E.D. headlights similar to this , but I've grown tired of them. They are also throwing off a weird pattern, that I just can't adjust to be proper. I used Sylvania bulbs before in my other car, but beside being more satisfied with the performance, I wasn't so with its longevity.
So, what kind of bulbs you guys are using, are you happy/unhappy with them, anyone with an aftermarket headlight set and how is that working out?
Vendor
GeneralDriver, have you tried Putco headlight bulbs? They are superior to both ordinary bulbs and OEM halogen bulbs and cast a longer and wider light beam, when compared to similar original equipment bulbs. As for the aftermarket headlights, you can find plenty of them for your Cruze here.
COTM Winner
Philips Xtreme Vision made a huge difference in my old Cruze (so did aiming them correctly vs the factory setup). Didn't burn out in the 3 years I had them
Likewise, I had Silverstars in the Cavalier from 2012 until we got rid of it and never had a problem.
COTM Winner
Those seemed to only last 9 mos - 1 year on my Volvo. But they're known for going through bulbs like crazy (full-on DRLs)
Interesting - the Cav had separate highs and lows, so it just ran the highs at low power for the DRLs. Probably helped tremendously.
I'm sure it also helped that I replaced both ground wires to the low beams as the both managed to "break" after I installed the headlights (one side had broken beforehand - as it is why that side's low beam stopped working, and why I bought the Silverstars to replace the low beams - only to have that side still not work; the other broke shortly after, but I already knew the cause when it happend).
