Here is the circuit diagram:
But this will have to wait until they fix this board, won't let us post photos.
A 30 amp fuse powers both seats. if one seat is working other should work too.
Heater temperature and blower heated seat controls are just door bell type push button switches that fire commands to the Seat heating control module that controls both seats, actually four heating elements two are in series for each seat. Control module is GM part # 13502042, can look this up on the net, runs around 60 bucks. Its located at the very front of the drivers seat bottom.
Heating elements are not cheap at 100 bucks each, times four, Just a piece of nichrome heating wire, with others break open the stitching, find where this long wire is broken, use a special solder to repair it and sew it up again.
It amazes me, can go to any store, buy a 120VAC heating pad, with a line cord, controller with three different settings, the heating element, and the pad for ten bucks, sure getting screwed by the car manufacturers. Four such heating pads will cost you 40 bucks, for the Cruze for essentially the same thing, looking at 500 bucks. 12 volts requires a lot less nichrome wire.
Only other element is a heat sensor that feeds back to the control module. Sure it just a simple thermostat, but can't seem to find it in the parts list. As usual, the shop manual does not show the resistance of the heater elements, but have another seat to compare that with.
Control module also has to be programmed, here is the procedure.
Heated Seat Control Module Programming and Setup
The seat heating
control module must be programmed with the proper calibration software. The module stores and utilizes this information however if it is not properly configured with the correct calibration software, the seat heating control module will not control all of the vehicle features properly.
Ensure that the following conditions exist in order to prepare for seat heating
control module programming:
- The battery is fully charged.
- The MDI data link connectors are secure.
- The scan tool is loaded with the most current software version.
- All disconnected modules and devices are reconnected securely.
- This entire procedure has been reviewed before proceeding.
Do not reprogram the seat heating
control module unless directed by a service procedure or a service bulletin.
Seat Heating Control Module Programming
To program and setup an existing or new replacement seat heating
control module, perform the following procedure:
- Access the Service Programming System (SPS) and follow the on-screen instructions. Refer to Service Programming System (SPS) See: Testing and Inspection\Programming and Relearning\Service Programming System (SPS).
- On the SPS Supported Controllers screen, select HVSMF Front Seat Heating Control Module - Programming and follow the on-screen instructions.
If the HVSMF Front Seat Heating
Control Module fails to accept the program, verify all scan tool and seat heating control module connections are secure.
Note: After programming is completed, perform the following to avoid future misdiagnosis:
- Turn the ignition OFF for 10 seconds.
- Open and close the door.
- Connect the scan tool to the data link connector.
- Ignition ON, engine OFF.
- Clear all DTCs from all modules."
Wife wanted electrically heated seats with our 2LT and was the only option we elected to purchase for a 1,000 bucks, also included leather, better radio, better suspension, and the spare tire and a jack. Considered this to be a bargain.
Tell her to use a very gentle touch on that climate control module, some guy here hit it too hard, can't just replace that switch, have to buy the entire control module for $$$$$$.
