1 - 20 of 22 Posts
I have bench tested installing a heated wheel in my Gen1 Diesel Cruze, 2014. I HAVE NOT as of this writing actually installed anything in my car. I am convinced that this is workable. Maybe not worth it cost wise to some, but I am keeping my Cruze forever, so depreciation doesn't matter, and so on... I'll answer questions as needed, and provide pictures if you want. But the guy that I referenced from YouTube pretty much covers the whole thing (on a Volt). The process is almost the same for Cruze, but a few more things are required to make it work.
Required parts:
  • Steering wheel with UVD RPO (this is the heated wheel)
    • Can be from a Verano, but you need a new airbag or airbag cover. Comes in brown or black leather
    • Sonic steering wheel with UVD will also work; GM P/N 42587908
  • Clock spring from a Verano. This is used to pass the extra circuits (3-4 total depending on what you want to do); GM P/N 23425376
  • Some wire to run from the steering column down to the under dash area. I am using 16AWG for the 7.5A circuit, 22AWG for the signal/LED indicator
  • 2 Terminals to add to the 10 terminal connector on the IP side (plugs into the clock spring); GM P/N SAIT-A03T-M064
    • You'll need 4 if using a Sonic wheel
    • You only need one, the second one illuminates an LED when the heated wheel is on
    • Terminal 9 is for LED, terminal 10 is for switch
  • A momentary switch (LED optional)
  • Add-a-circuit fuse piggyback adapter capable of at least 7.5A circuit
I am not responsible for you being dumb. This is a no dumb area. Before you do anything, disconnect the battery entirely from the vehicle, and wait at least 10 minutes before you remove the airbag. If you are not comfortable doing any of the following work, do not attempt. This mod is not difficult, but the airbag is an explosive, and you must proceed with caution. Wiring SHOULD NOT under any circumstances be hacked together. I recommend heat shrink tubing and GOOD crimps using proper crimping pliers. All wires should be strain relieved, and avoid kinks/pinches. Vehicle fires due to improper wiring are a real thing, and EXTREME CAUTION should be practiced.
If you use a Verano wheel, you need to get a new airbag, or disassemble and swap over an airbag skin at your own risk. This guy does it here, he's doing it on a Volt, which is similar:
He also shows how to do the install in general here:
The Verano wheel will plug into the new clock spring directly:
  • main 10 terminal connector
  • 2 terminal power and ground for the 7.5A circuit
  • Verano airbag has 2 connectors, so if you get a new airbag, it should work, this is the easiest thing to do if using a Verano wheel
On the IP side:
  • Connectors should plug in. You'll need to run 1 or 2 circuits for switching (1) and LED (optional)
  • The 7.5A circuit needs to be wired into ignition switched power, and a ground (black is ground)
  • Terminal #10 on the 10 terminal connector needs a TEMPORARY ground to activate the heated steering wheel module. That is what your momentary switch is for
  • If you want an LED to come on when the heat is on, then Terminal #9 can be wired to the - side of a 12V LED, apply 12V ign/accy switched to the + side of the LED
If you use a Sonic wheel:
  • The cruise control buttons WILL NOT WORK. THEY are incompatible with the Cruze BCM. You will have to swap out your Cruze cruise button module. I would recommend swapping in the radio control buttons, as well as the little wiring harness that is there as well. You'll need to add 1 or two circuits to the ten terminal connector on both sides of the clock spring (as the wiring is different on the Sonic).
  • The Sonic buttons are white back-lit BTW
  • Look at the two clock springs. There are two connectors on the new clock spring for the airbag, and only one on the Cruze. Neither of the new ones will connect to a Cruze airbag. Match up the connector with the similar colors, and swap the electrical connector from the Cruze clock spring to the Verano clock spring.
    • Alternatively, you could modify the keyway so that it will fit
  • The rest is the same as stated above.
  • This dude ends up using a Sonic wheel on his Volt. The Sonic/Volt cruise control modules are compatible, so it's a little easier:
You can skip running extra terminals and wires through the clock spring (except the 7.5A circuit) if you install a momentary button ON the steering wheel. There's probably someplace to make this work, I haven't looked into it, but there's no reason it shouldn't work. The steering wheel heating control module (inside the steering wheel) works on analog signals. Simply temporarily grounding terminal 10 will turn it on, temporarily grounding a second time will turn it off. The module self regulates to 90F.
Discussion Starter · #2 ·
IP side connector end view (X1), as viewed with the release clip on top. 10 on the left, 1 on the right:
  • 1: Horn switch signal
  • 2: Ground
  • 3: Cruise control Switch
  • 4: Steering wheel resistor ladder Signal
  • 5: 12V reference
  • 6: LED backlight dimming
  • 7-10: not occupied (you'll want to occupy 10 and 9 for the signal and LED)
Steering wheel side connector end view (X3), as viewed with the release clip on top. 10 on the left, 1 on the right:
  • 1-4 not occupied (though you'll want to occupy 1 and 2 for the signal and LED)
  • 5: LED backlight dimming
  • 6: 12V reference
  • 7: Steering wheel resistor ladder Signal
  • 8: Cruise control Switch
  • 9: Ground
  • 10: Horn switch signal
Motor vehicle Automotive design Vehicle Steering part Car
The Verano wheel will likely be easier (provided you get an airbag/cover for it). No rewiring required since the steering wheel controls have the same resistance ladders (exception being fwd collision warning for Verano).
I had to rewire the Sonic wheel harness due to some unexpected wires. The factory manual does not call out everything, some connectors are different, as are wire coloring.
Some more notes if using the Sonic wheel:
  • Radio buttons work (they're white backlit)
  • You'll have to trim the bottom plastic bezel around a small section of the clock spring (see photo below)
  • I ended up just trimming the keyway on the airbag connector, it was a piece of cake (see photo below)
  • Finding a ground was actually harder than I'd have thought. I ended up running a self tap screw through the IP structure to the left and above the fuse box. I popped out the headlight controls to access better
  • I found an even better place to install the button. Right below the key cylinder. This way, only the power and ground have to be run down the steering column to the fuse panel area (see photo below)
  • The power and ground wires easily routed to the right of the column following the existing harness, then below it, just above the knee airbag, finally around to the fuse panel area. I sleeved it in anti-abbrasian wrap
  • Using the OEM terminals in the 10 terminal connector at the back of the clock spring worked fantastic
  • All under steering column wiring was wrapped in anti-abbrasian wrap
  • I could have swapped the Cruze steering wheel harness into the Sonic wheel. I elected to use the existing harness, but repopulate 2 of the connectors, and swap one from the Cruze that was incompatible with the Cruze cruise control buttons
  • Blue loctite and 33 ft-lbs for the T50 steering wheel screw
  • The Sonic heated steering wheel control module is different from the Verano's module. Two of the wires are swapped, though the colors and functions are similar. The output of the Verano module for the LED is 12V+. The Sonic module provides a ground for the LED. I used the + that I ran from the fuse panel as the supply for the LED (only live during IGN ON/ACCY modes), and then used the switched ground on the module. Works perfect. I grounded my switch using the same ground wire I ran to the IP structure.
    • I removed the left side Cruze connector from the Cruze steering wheel harness
    • I replaced the Sonic connector with this one. There are some spare wires and the colors are slightly different. The attached images show what it needs to look like. The terminals are NOT the same, but with some effort, they will fit, and it does work. The connector is tight to plug it in as well
  • There is a 3 terminal connector that was unexpected. Two of the wires need to be removed from this connector, to be repopulated by two of the wires that were in the oddball 8 terminal connector out of the Sonic. Again, see images of before and after
  • The 10 terminal connector has to have one wire moved from Pin 4 for Pin 1. You'll now use 1 and 2 for control and the LED light (open terminals 9 and 10 on the IP side)
In total, it took me 8 hours by myself in two stages. I did all the IP related stuff first. Then, I worked on the steering wheel wiring.Then tested it out. Looks good, works good. Should have been an option from the factory.
What did you find to use for the Chevy airbag? There's got to be one that fits the Buick wheel.
· COTM Winner
Bumping this back up, since this is one of two "features" I'd like to add in the Cruze (since my wife is unaware she's never getting a new car unless something physically happens to the Cruze, I'd like her to at least have a heated wheel and Android Auto), it looks pretty straightforward.
On the similar thread on the Volt forum for adding one to a Gen 1 (which shares our steering wheel, unlike my Gen 2), I noticed that the buttons on the left side of the wheel are slightly different - in that it has a heated steering wheel button where the cruise control active toggle was, and that has shifted to the top of the cancel button on the far left, though I assume that may not work with our car since it's likely a momentary instead of a toggle?
Any idea what that's actually out of and if it'd work in lieu of putting a separate button on the wheel like you did (which looks plenty fine as well, so I have no issue doing that too)?
I did not try out the switch panel that has the factory heated steering wheel button on it. My assumption (though please try it out, I am curious to see if it works!), Is that it won't work. The resistor ladder for the cruise control circuit is different, depending on the car (Cruze and Verano are the same, but like Sonic and Trax are different). Cruze wants open/closed circuit for the BCM to turn cruise on or off, and the rest of the circuit is different too. Vs an always closed circuit. It's just reading various voltages. But I have not tried it.
The steering wheel is out of a 2020 Sonic as I mentioned above. The steering wheel assembly comes with everything except the airbag and clock spring.
Sent from my SM-G781V using Tapatalk
· COTM Winner
Do you know which vehicle has that factory heated switch panel? Your '20 Sonic wheel looks to have the same switch panel as our cars came with - or did you swap yours over?
Discussion Starter · #10 · (Edited)
Yeah it was the Sonic. It's difficult to comprehend I know...for a time, the Sonic being one of if not the cheapest car you can buy in the States, was offered with a heated steering wheel as an option through 2022 MY. And yet, through all of C7, most expensive car GM had, you couldn't get a heated wheel. What is wrong with that?
· COTM Winner
Yeah, there are some incredibly bizarre optioning choices. The 2nd gen Cruze and Volt could be had with heated outboard rear seats...my brother's Regal GS ('18 - but includes '18-20) can't...though the Insignia in Europe can.
Reactions: thebac
That blew my mind when I bought Hannah's '16 Premier. Who needs heated rear seats? :LOL:
· COTM Winner
My buddy's daughter, apparently. She asked if they make heated rear seats, to which he answered yes, and then said she wanted them (in their '04 Suburban or '03 Yukon) to which he immediately laughed.
I'd love to add them into my Volt, but then I remember that I don't at all care - I don't sit back there. :ROFLMAO:
· Administrator
I may have found a blank cover for the Verano wheel. Its actually for an Opel Astra, but is the same design.
The airbag mounting looks to be the same as the Cruze cover, too.
Still havent found the button that Number2 used, though.
$18.50 + shipping is not too bad. I ended up buying one form a junkyard in Australia with help from another member. I cannot off the top of my head remember the cost, but it was more than that.
· Administrator
The resisters for the manual shift are different too, but they still worked for me. I installed a 2010 Camaro wheel in my Cruze. I had to swap out the left set of buttons, but all else worked as stock.
Discussion Starter · #17 ·
· COTM Winner
Is the intention with the Verano wheel that there is greater compatability between it and its own clock spring so that all you need to do is wire in the two wires to the terminal for power/ground from the switch and that's it, whereas the Sonic wheel requires swapping components over from the Cruze clock spring to the Verano one?
I actually couldn't find a heated steering wheel button I liked, so I had one custom made from a company in Australia. It was like $35 shipped.
Aha, so that's where it came from.
Thanks for that. :)
Well, thats kind of the idea. Number2 stated he couldnt find a non-Buick cover for the airbag.
Discussion Starter · #20 ·
Verano was the choice because I knew it would fit and I knew it had all the right parts. Since Verano uses the ECC module for turning on the heated wheel, my plan was to use that wire (that does not exist on Cruze) to go to my aftermarket button.
What I did not know originally was that the Sonic had an available heated steering wheel. Which turns out to be exactly the same shape as Cruze. Also uses the same clock spring as Verano. The only incompatible part was the factory cruise control button module. Since the Cruze cruise on/off switch is a latching toggle, and the Sonic cruise on/off is a momentary switch, I do not believe it is compatible with the Cruze BCM....though I did not verify. Logic says it won't, but I certainly could be wrong.
Additional....the different cruise control button module has a totally different connector than either the Cruze or Verano. So to attach the old cruise control button module, you have to re pin the old connector.
The Verano wheel will work completely and plug into the clock spring as expected. You just need to pick up the pins on the other side (IP) so you can install a button. But you still need to get a Verano/Sonic clock spring to pass the 2 high current wires. B+ for the grid, and the ground (since they do not ground the high current wire on the steering wheel itself).
1 - 20 of 22 Posts
