Here's a picture of the code on the display.
Learned something, so one would require a Canadian shop manual? Does that code move to the left for digits higher than 9?TheStig has a Canadian Cruze. The errors are numeric instead of text. As far as I can tell it's so GM doesn't have to generate both English and French language versions of the text along with the associated support for changing languages.
Thank you sir. Hopefully it just needs some coolant, and isn't leaking somewhere.Code 4 is suppose to be for Canadian vehicles. It means "Air Conditioner off due to high engine temperature"
Copied and saved for future reference.Here is a list of possible codes:
On the Canadian base level cluster, vehicle messages appear as code numbers.
4 Air Conditioner off due to high engine temperature
25 Left front turn indicator failure
26 Left rear turn indicator failure
27 Right front turn indicator failure
28 Right rear turn indicator failure
35 Replace battery in radio remote control
53 Tighten gas cap
65 Theft attempted
68 Service power steering
75 Service air conditioner
82Change engine oil soon
84Engine power is reduced
95Service airbag
Kind of what I expected with the original symptoms. There will be some air caught in the radiator - it will burp out over the next few thousand miles. Keep an eye on it as I think you have more than the usual seep/loss of coolant.It was just below the lower hose. Got all the air out of the system.
