{2012 Chevy Cruze LT 1.4L Turbo}
I purchased my Cruze 3 months ago. I purchased it with a check engine light on but the codes that were being shown were just a couple of sensors MAF and MAP and P1101 which is an Intake Air Flow System Performance, other than that no other problems. The Cruze ran great on the test drive and on the way back home which is a 40mi drive. I fixed the problems and cleared the codes. A couple of weeks went by and I was noticing that Cruze was running, a little differently, I don't say it was running rough because I feel it's too harsh of a describing word. It was like a soft pulsating when at an idol as if it needed more air. The check engine light came back on indicating that there is a Cylinder 2 Misfire and the Stabilitrak Light is on. After doing some research I went under the hood and got to work. I replaced the following...
- Valve Cover Gasket
- Coil Pack Harness
- Spark Plugs
- Coil Pack
- Cleaned Fuel Injectors
- Purge Valve
- PVC Hose
- Fuses and Relays I did the trick of switching one Injector for the other, #4 was now #2 and I got the same results. Cylinder 2 Misfire and Stabilitrak lights are still on as well. I parked the Cruze and continued researching. I changed gears and started changing just random parts on my car, everything non-engine performance related and the Cruze sat for 3 to 4 days. The next time that I got into my car and drove it, it was like the car gods came and fixed the Cruze. The Cruze felt and ran like it just made its way off the showroom floor. No engine light no Stabilitrak Light. So I just left it alone for a couple of weeks. For almost 2 months the Cruze is throwing the P0302 Misfire code and displaying the check engine light, it will be on for a while and then goes away and it happens every time I take the Negative Terminal off the battery. Any advice would be greatly apperciated
