Hi guys, so i am french and my English is not very good sorry, i have a chevy cruze lt diesel 2010, since 1 month i have a big problem electronic, i explain, i drive normally and my mil light and the heater glow light go on and my chevy have trouble, no power for 20 seconds, after all is right and it start again 5 minute later etc etc, so i read much post on this big forum so i change my negative cable i put another new (not oem), i clean all ground point, all was right 3 days and its re start the same problem, and with another, the display radio black screen, i remove the fuses for radio and display i reconnect the fuses Nothing display rest black, 5 days later the display is back alone, and another problem when i drive backward the heater glow light and the mil light go on and the motor stop, so i remove the fuse sensor current battery and no problem to drive backward, but the problem come back sometimes when i drive normally, my battery charge at 14,9 volts and i have no code on obd, do you have any ideas for this problem please.....
